| CSRB vs. CSRB+ http://paulcbuff-techforum.com/viewtopic.php?f=8&t=709 |
| Author: | evp33 [ Tue Jul 06, 2010 10:47 pm ] |
| Post subject: | CSRB vs. CSRB+ |
Hello, I was curious as to what the remote jack is for on the CSRB+? 2, I will be investing soon and wanted to know what the difference was versus the CSRB? and 3, In what way does CSRB+ function as a trigger? Is it like the PW plus 2? ( i will be using 2 CSRB+ as receivers for both off-camera speedlites and 2 AB800 strobes) Please clarify |
| Author: | Liquid Rhino [ Wed Jul 07, 2010 11:26 am ] |
| Post subject: | Re: CSRB vs. CSRB+ |
1. the remote jack on the +'s allows them to link up to AB & White Lightning units to control flashpower remotely when used with a Cyber Commander. 2. Using the CST with either CSRB or CSRB+, all the flashes set will fire. Using the CC with CSRB , all the flashes will fire. Using the CC with CSRB+ ,all or any individual or group will fire, adjust flashpower output or meter based on your input. Using both CST & CC - you meter, adjust power & test on lights (whether independent, grouped or all) with CC in hand and use CST on camera to trigger the last selections you made with cc. 3. CSRB+ isn't a trigger, you'll need either a CST or Cyber Commander (or both, depending on your requirements) to trigger the CSRB+ or CSRB units. It's suggested if you're thinking of using the Cyber Commander at any point, you should go with the CSRB+'s, otherwise the CSRB should work for most other cases. hope this helps. |
| Author: | Technical Support [ Wed Jul 07, 2010 5:16 pm ] |
Thanks Liquid Rhino. |
