Fri Jul 09, 2010 1:19 am
Would it be possible to custom cut a gel sheet and attach it to the outside of the Einstein dome, or would heat be too much of an issue?
Fri Jul 09, 2010 5:44 pm
You are probably going to suffer the same results as if you put the gel right on the flash tube. A melted, smoking mess.
Mon Jul 12, 2010 12:29 pm
i agree that this is not a good idea. better to gel the modifier.
