| Gelling Einstein Dome http://paulcbuff-techforum.com/viewtopic.php?f=8&t=714 |
| Author: | CanadianEh [ Fri Jul 09, 2010 1:19 am ] |
| Post subject: | Gelling Einstein Dome |
Would it be possible to custom cut a gel sheet and attach it to the outside of the Einstein dome, or would heat be too much of an issue? |
| Author: | OregonWineLover [ Fri Jul 09, 2010 5:44 pm ] |
| Post subject: | Re: Gelling Einstein Dome |
You are probably going to suffer the same results as if you put the gel right on the flash tube. A melted, smoking mess. |
| Author: | Technical Support [ Mon Jul 12, 2010 12:29 pm ] |
i agree that this is not a good idea. better to gel the modifier. |
