| WL X3200 Modeling light intensity varies ? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=731 |
| Author: | energystudiosinc [ Thu Jul 15, 2010 9:26 pm ] |
| Post subject: | WL X3200 Modeling light intensity varies ? |
Greetings to all, I have an X3200 monolight that the modeling lights intensity goes up and down by itself and at other times its perfectly fine. The actual strobe part works great. Is there something I can do about this condition or does it need to be sent in for repair ? Is this a condition that can wait a bit longer before I send it in for repair ? I tried replacing the blub but the same thing happens. Thank you for your reply in advance. Sincerely, Joseph P. |
| Author: | Technical Support [ Fri Jul 16, 2010 2:16 pm ] |
| Post subject: | Re: WL X3200 Modeling light intensity varies ? |
Try changing AC circuits and see if the problem persists. Otherwise, the light will need to come in. If it is under 5 years old, sending it in under the warrranty period would be best. If over 5 yrs old, any time is as good as any other. |
| Author: | energystudiosinc [ Fri Jul 16, 2010 5:14 pm ] |
Technical Support wrote: Try changing AC circuits and see if the problem persists. Otherwise, the light will need to come in. If it is under 5 years old, sending it in under the warrranty period would be best. If over 5 yrs old, any time is as good as any other. Thank you for your reply. I will send it in when I'm down for a few weeks. Thanks again. Joe |
