 [ 12 posts ]
Sat Jul 17, 2010 1:59 am
Hi everyone,
Curious if anyone is using Einsteins with Hassy Digital? If someone could explain if and how one would use the Einsteins with Hassy Digital, I would really appreciate it.
Im considering making the jump to MF but have no clue how I would integrate my Einsteins!
James
Sat Jul 17, 2010 2:03 am
I actually can't see how the usage of einsteins would differ from using them with a regular DSLR?
I mean, I don't own or use digital HASSY, but I use my AB lights with both, dslr and film MF cameras, and it's the same. I even think digital hasselblads have a hotshoe mount, that would fit the CC, don't they?
Sun Jul 18, 2010 5:45 pm
I'm thinking the same thing ShOo, but was hoping for a bit of confirmation from someone using the combo.
Thanks for the comment...
Mon Jul 19, 2010 9:19 am
Lights are lights, no matter which camera you use. Would you use natural light any differently?
The only differences i could see would be in synchronization, but that should affect all lights equally, and is more of an operational issue than compatability issue.
Mon Sep 24, 2012 2:42 pm
Hi - I now have a Hasselblad H4D40, and have tried it with my AB800's. It works at lowish sync speeds (1/200th) but not the full 1/800th that the Hassy leaf shutters allow. Can anyone confirm that if I move to Einsteins that the flash output would be compatible with sync at 1/800th? I have a Vag Mini power pack and want to shoot outside at wide apertures, nuking the sun.
Many thanks for any advice.
Bill
Mon Sep 24, 2012 2:56 pm
If it is out of sync (i.e. there is no flash contribution) with Bees, then the E640's would likely not sync either (under identical circumstances).
To be honest, I am not super familiar with the Hasselblads, so I will speculate a bit.
First, how are you triggering the lights (direct sync cord, remotes (which ones), etc.). Depending on the remote, there could be a latency introduced that does not allow for very fast shutter speeds. See if direct cord triggering works.
Is there a way to change sync options? Older systems had "X sync" and "FP sync" and others marked on the lens where the PC terminal would be. Is there a menu option that allows for this? If so, try the different options and see what happens.
Mon Sep 24, 2012 3:33 pm
many thanks for the prompt reply. I'm using some early (4 - 5 yr old?) AB remotes (RFT-1) that work very well with my Canon DSLR gear. I will try some more accurate power / shutter speed combo tests with sync cord vs radio and see what happens. I'll also see if the camera has different sync options. Thanks again, Bill
Mon Sep 24, 2012 4:48 pm
I am not sure on the latency of the RFT1 remotes, but that could be where the problem lies as I believe it is somewhat slow by today's standards. The direct PC connection will definitely tell us if that is the problem.
Wed Sep 26, 2012 7:37 am
I use Einsteins and even an AB 3200 triggered with either Cyber Commanders or CST's on a H4D with a 50 back syncing at 1/800 without any latency problem. The camera focusing light works at half press without triggering the Buff lights
Ken R.
Wed Sep 26, 2012 8:53 am
Is "back syncing" a timing function that can be dialed in via a menu setting?
 [ 12 posts ]
