| Since you're so helpful. http://paulcbuff-techforum.com/viewtopic.php?f=8&t=741 |
| Author: | 10box [ Tue Jul 20, 2010 8:50 pm ] |
| Post subject: | Since you're so helpful. |
Since you’re so helpful. I have (8) AB units enclosed in an overhead box. I am needing to remotely control modeling lamp on / off and units on / off. All changes would be made as a whole to all units, i.e. all off at once, all on at once. I have no access to the lamps. When I asked your customer service person, they suggested a switched plug for the power on / off but said to use the LG4X for the modeling lamps. Is there another path to controlling the lamps? I have no need to change flash output remotely. Thanks for your help, and I enjoy using your product. |
| Author: | Technical Support [ Wed Jul 21, 2010 9:16 am ] |
| Post subject: | Re: Since you're so helpful. |
2 LG4X's would be the least expensive route. Otherwise, CyberCommander and CSR+ recievers would be the only other option. |
