| 47" Octabox diffusion panel cleaning http://paulcbuff-techforum.com/viewtopic.php?f=8&t=742 |
| Author: | ocabj [ Wed Jul 21, 2010 11:25 am ] |
| Post subject: | 47" Octabox diffusion panel cleaning |
I was just curious as to what's the best way to clean the two diffusion panels for the 47" octabox, or any other of the PCB softboxes for that matter. Also, I poked around the site and was checking to see if replacement panels could be ordered but didn't see any. If I needed replacements, is this just something I could call in and place a special order for? Thanks. |
| Author: | Technical Support [ Wed Jul 21, 2010 11:36 am ] |
| Post subject: | Re: 47" Octabox diffusion panel cleaning |
You can call and see if any are available, but this not a regular sock item, as they are shipped from the factory as a whole unit. You can clean them using a gentle cleaner like woolite. You do not want to use bleach or anything with brighteners. |
