Sync Speed
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=745
Author:  Rick [ Fri Jul 23, 2010 9:55 am ]
Post subject:  Sync Speed
I just got my Einsteins and CC. I noticed on the CC that the shutter sync speeds go from 125 to 250. I have a Canon and the fastest shutter sync speed is 200. What speed should I use on the CC for metering purposes?
Author:  PowerEngineer [ Fri Jul 23, 2010 10:10 am ]
Post subject:  Re: Sync Speed
Hey Rick,
Check the final post by Luap in this thread:
viewtopic.php?f=8&t=673&p=4223&hilit=commander+shutter+canon#p4223
Basically you are stuck with 1/250 for now but there may be a firmware upgrade in the future to support 1/200.
If you are lighting the scene totally with flash (no ambient) then it won't matter as the exposure is dictated by aperture and ISO and shutter speed won't play a role. If you have ambient mixed ambient and flash then your ambient will be off but not too much. I shoot a 5d mkII and I'm stuck at 1/160 so I just shoot, chimp, and adjust to taste. Hope this helps.
Author:  Rick [ Fri Jul 23, 2010 1:56 pm ]
Thanks for the reply. Now another question. To get proper metering outdoors when using the CC and the Einstein as fill flash, would it be best to use 1/125 shutter speed so that the metering is exact?
Author:  PowerEngineer [ Fri Jul 23, 2010 2:20 pm ]
Using 1/125 is certainly a reasonable approach. For me personally though, I tend to just meter at whatever is closest to the shutter speed that I want to use and take that as a starting point. Then I adjust from there and chimp a lot... but I'm also coming from using small flash and no light meter at all. Both approaches have their merits and it really depends on what suits you best.
