Fri Jul 23, 2010 2:18 pm
White Lightnings - the spring lever and four clamps used to mount a softbox to the lamp is getting dry and/or dirty. When I mount a softbox I have to push the lever partially back by hand or the clamps won't grip 100%.
Can I spray some WD40 or graphite on it to loosen it up without ruining the lamp or myself?
Thanks, Russ
Fri Jul 23, 2010 4:56 pm
We do not recommend spraying lube into the light. It can get on parts it shouldn't and cause more damage. Ideally, it should be sent in for repair.
