Sun Aug 01, 2010 5:45 pm
Trying to figure out how to change the flash power of the individual Einsteins remotely with the CC. I can't find specific directions.
Mon Aug 02, 2010 9:03 am
For specifics on initial set up, please see this post: viewtopic.php?f=8&t=515
Once properly set up, you would select the channel Einstein is set to by moving the left joystick left or right. The channel selection is indicated by the green dash at the top and bottom of the chart. Once selected, moving the left joystick up or down will adjust flash output. Be sure all lights are set to the same frequency as Cyber Commander.
Tue Aug 03, 2010 10:52 pm
I believe I have done that correctly.
Will the LED power display on the Einstein change as I move the joystick?
I don't see it going up or down.
Wed Aug 04, 2010 9:13 am
The flash power bar will move up or down with Cyber Commander. Model lamp power bar may or may not, depending on other settings. Double check frequency on both CC and E640. Also, does the Cyber Commander say "Einstein E640" in the lower right in blue when you attempt to adjust?
Wed Aug 04, 2010 10:28 am
Yes it will.
RMS
