| Cybersync - selective firing http://paulcbuff-techforum.com/viewtopic.php?f=8&t=811 |
| Author: | jrsforums [ Fri Aug 20, 2010 1:25 pm ] |
| Post subject: | Cybersync - selective firing |
If I am using non-AB flash/strobes, being fired by CSR+....can I selectively turn on/off which of the different devices? I assume, if it could be done, I would need to set it up on the CC, but could a CST be then used to fire them? Thanks...John |
| Author: | Technical Support [ Fri Aug 20, 2010 4:05 pm ] |
| Post subject: | Re: Cybersync - selective firing |
Yes, if you have CSR+ or CSRB+ receivers you can selectively turn OFF or ON Buff or NON Buff lights. You will have to use the Commander in order to acheive this. Once the unit is in the OFF(STANDBY) position, the CST can not fire unit. |
| Author: | Technical Support [ Mon Aug 23, 2010 8:52 am ] |
to add, you can set up different combinations of lights in groups, and switch between groups to selectively fire or not fire lights. This would be quicker than going into the menu to turn them to and from standby. However, this is limited to 8 groups (or 8 combinations). |
