| AB800 won't fire when CSRB+is plugged in http://paulcbuff-techforum.com/viewtopic.php?f=8&t=818 |
Page 1 of 2 |
| Author: | sempaidavid [ Tue Aug 24, 2010 7:09 pm ] |
| Post subject: | AB800 won't fire when CSRB+is plugged in |
I just got my new CSRB+ and a CC. If I plug my CSRB+ into my AB800 with the phone jack the strobe will not fire properly. The flash tube faintly flickers. However it will fire fine with the regular sync cord. When the phone cord is used the dump light remains lit. I switched cords and also switched my AB800, still the same result. Please help, is there something wrong with my new CSRB+? |
| Author: | rms956 [ Tue Aug 24, 2010 9:21 pm ] |
| Post subject: | Re: AB800 won't fire when CSRB+is plugged in |
Make sure you leave a dummy plug (or your sync cord but disconnected from your CC or camera) plugged into the AB when the phone jack is used. Also did you setup the CC with all your lights per instructions first? RMS |
| Author: | sempaidavid [ Tue Aug 24, 2010 9:24 pm ] |
rms956 wrote: Make sure you leave a dummy plug (or your sync cord but disconnected from your CC) plugged into the AB when the phone jack is used. Also did you setup the CC with all your lights per instructions first? RMS Yes the dummy cord is in, also the CC is setup. Thank you for your ideas. |
| Author: | Technical Support [ Tue Aug 24, 2010 9:27 pm ] |
Press up on the left joystck, this will refresh the command. Also, be sure the light's power is dialed up to at least -5f or higher (the vertical bar should show atleast some blue). |
| Author: | sempaidavid [ Tue Aug 24, 2010 9:32 pm ] |
Technical Support wrote: Press up on the left joystck, this will refresh the command. Also, be sure the light's power is dialed up to at least -5f or higher (the vertical bar should show atleast some blue). To be clear.... This was happening before I even took my CC out of the box. As soon as the receiver is plugged in via the phone cord this happens. I was testing it using the test button. I only tried the CC after switching to the sync cord. |
| Author: | sempaidavid [ Tue Aug 24, 2010 11:07 pm ] |
Well I guess that I should not have assumed that the batteries that were shipped with the receiver were good. I Changed them and all is well. |
| Author: | Technical Support [ Wed Aug 25, 2010 9:00 am ] |
Plugging in the RJ11 (telephone) cord overrides the back panel. It is not unexpected to have a light switch so that the red dump light comes on and a tickle flash fire upon initial connection, so the absence of CC would only reinforce this. As for the batteries, we do get these in bulk, and there may be bad cells out there. However, changing batteries may have simply reset the receiver from any settings made in testing, giving the appearance the old batteries were faulty. |
| Author: | Luap [ Wed Aug 25, 2010 1:00 pm ] |
I've seen no mention of doing "Open Studio" on the CC and setting this system up. If this isn't done the CSRB+ can't know where to set the lights and the results reported would be expected. |
| Author: | sempaidavid [ Wed Aug 25, 2010 4:33 pm ] |
Technical Support wrote: Plugging in the RJ11 (telephone) cord overrides the back panel. It is not unexpected to have a light switch so that the red dump light comes on and a tickle flash fire upon initial connection, so the absence of CC would only reinforce this. As for the batteries, we do get these in bulk, and there may be bad cells out there. However, changing batteries may have simply reset the receiver from any settings made in testing, giving the appearance the old batteries were faulty. You were right all along, it was a setup problem with the CC after all. Thanks so much. |
| Author: | justiceimages [ Wed Aug 25, 2010 10:21 pm ] |
Got my CC and three CSRB+ units today - two work beautifully, the third was fine for a number of test shots then went gray. Guess I'll be stopping by Wallyworld for a huge pack of AAs ... I can't afford another yet another case of rechargeable AAs for these guys. :-) If that doesn't work, I'll run the test setup AGAIN (did so 3 times, which is why I think it's a battery issue.) |
