| Whats the use of the two buckle straps on vagabond bag? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=830 |
| Author: | buurin [ Tue Aug 31, 2010 4:46 am ] |
| Post subject: | Whats the use of the two buckle straps on vagabond bag? |
Just curious, I can't find a use for the 2 straps with the plastic buckles on the vagabond bag. |
| Author: | mgimagery [ Tue Aug 31, 2010 7:06 am ] |
| Post subject: | Re: Whats the use of the two buckle straps on vagabond bag? |
I use them to attach it to the lightstand to keep it off the ground and keep the stand more stable instead of having to sand bag them. |
| Author: | PowerEngineer [ Tue Aug 31, 2010 7:12 am ] |
In addition to buckling the VB to my light stand when shooting, I'll also sometimes buckle the folded stand to the VB to carry them short distances, especially if I don't have my stand bag with me. I originally thought the buckles would be useful for strapping the VB to my rolling light case but I haven't found a good way to do that yet. |
| Author: | Liquid Rhino [ Tue Aug 31, 2010 10:47 am ] |
It's a chihuahua holder. It keeps them from running around on a location shoot whenever a model insists on bringing one, duh! :P It's also useful when slipping the VB as an impromptu leg weight, ya know... when you gotta throw someone over the boat for being a rat - "ta sleep with tha fishies, see?" :twisted: |
| Author: | Raymond Ponce [ Wed Sep 01, 2010 6:41 pm ] |
I am due to get a Vega Bond and the use for it is, to STRAP it to a LIGHT STAND to keep your Light Set Up from tipping over....Hope that helps. :) |
| Author: | buurin [ Sun Sep 05, 2010 5:20 am ] |
Interesting. I didnt think the straps+buckles were strong enough to carry the weight of the battery+inverter. I'll give it a try. So you just strap it on to the lowest vertical section of your light stands? EDIT: Tried it out. Works good. I now see most of the weight is supported by the lightstand. The straps just sort of balance the battery |
