| Will PCB make higher ws Einsteins? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=838 |
| Author: | rhomsy [ Tue Sep 07, 2010 3:27 pm ] |
| Post subject: | Will PCB make higher ws Einsteins? |
Hi, I recently picked up an ABR800 and ordered 4 Einsteins. I also opted to equip everything (including my existing speedlites) with cybersyncs rather than expand upon my existing base of pocketwizards. Essentially, I'm buying into PCB all the way. The only think I wish was out there was a 1250ws or 2000ws Einstein. I would pick up a couple of these as well to add to my lighting. I know I could get the white lightenings, but I would rather keep everything digital like the Einsteins, so that everything can be controlled from a CyberCommander. Is this in the works? |
| Author: | Technical Support [ Tue Sep 07, 2010 3:40 pm ] |
| Post subject: | Re: Will PCB make higher ws Einsteins? |
There is no higher level digital flash in the works as of now. It is trickier to go from 640 to 1280Ws in the digital line than it was in the analog line. However, you can control most functions of an X3200 from the Cyber Commander as well with a CSR+ or CSRB+ reciever. |
