 [ 24 posts ]
Fri Sep 10, 2010 3:22 pm
I've compiled whatever information I can find on these two Vagabonds to compare relevant information. I hope this will be useful/helpful for everyone. Let me know if I need to add/correct anything on here:
Weight
Vagabond II : 18.6lbs
Vagabond Mini : 3.5lbs
Dimensions
Vagabond II : 10.5" x 8.5" x 6"
Vagabond Mini : 2.75" x 4.3" x 7.5"
Price
Vagabond II : $299.95
Vagabond Mini : $239.95 (should be cheaper if you factor in shipping costs (less weight))
Battery
Vagabond II : Sealed Lead Acid, 144 Watt hours
Vagabond Mini : LiCoxNiyMnzO2 Lithium battery, 130 Watt hours, no memory issues, no sulphating
Features
Vagabond II : One outlet, fast/slow switch, carrying bag/straps
Vagabond Mini : USB port (charging iPOD/phone, etc), stand clamp, TWO AC outlets, fuel gauge, quick change battery, option for 120V or 240V output
Performance Comparisons
Data from manuals or whatever information is available to me
Assuming Fast setting on Vagabond II
Recycle times and number of shots are approximate, for comparison sake.
160Ws
Vagabond II : 0.7 seconds recycle, 500-600 shots
Vagabond Mini : 0.8 seconds recycle, 400-500 shots
320Ws
Vagabond II : 1 second recycle, 500-600 shots
Vagabond Mini : 1.5 seconds recycle, 400-500 shots
640Ws
Vagabond II : 2 seconds recycle, 500-600 shots
Vagabond Mini : 3 seconds recycle, 400-500 shots
1280Ws
Vagabond II : 3.5 seconds recycle, 250-287 shots
Vagabond Mini : 7 seconds recycle, 200-250 shots
Overall the Vagabond Mini sounds awesome! The size, weight, better battery, and overall close performance to the Vagabond II makes this an instant purchase for me. I think I'll need to buy more than 1!!
Fri Sep 10, 2010 3:58 pm
Add to that a USB port (charging iPOD/phone, etc), stand clamp, two AC outlets, fuel guage, quick change battery, option for 120V or 240V output, and "fuel guage".
No fast/slow switch, however.
Fri Sep 10, 2010 4:07 pm
Thanks for that! I have updated the information!
Fri Sep 10, 2010 6:25 pm
Awesome specs for the mini! I will be ordering two...to start with. :lol:
Fri Sep 10, 2010 8:38 pm
Just a point to clarify, the 120V/240V option is by way of two different models. One Vagabond mini cannot switch output voltage. Just to avoid any possible confusion.
Sat Sep 11, 2010 1:29 am
what outlet will be shipped with the 240v version? i.e. will there be a local plug available for each country?
Sat Sep 11, 2010 6:18 am
From what I have read from Paul and he can correct me if I'm wrong, it will be the Australian plug. Reasons for this:
* A one plug for all voltages will run the risk of people by mistake frying their light if they do not switch the mini Vag to the correct voltage.
*The Australian plug design is the ideal size to fit the physical space available on the mini.
*The plug is as universal as can be without specifically creating a plug outlet design for every country on the planet. (err...likely not very cost effective)
All in all, with the Einsteins, CC and now the min Vag, I personally believe this is one heck of a system.
Alphabug, if you read this, mate, I'd forget those Elinchrom's.
Sat Sep 11, 2010 7:14 am
Excellent, I am in Australia so will suit me perfect. :) Will go well with my 5 Einsteins. :)
Sat Sep 11, 2010 10:28 am
Redback wrote:
* A one plug for all voltages will run the risk of people by mistake frying their mini Vag if they do not switch it to the correct voltage.
This primary reason is so that you dont fry a light. The Vagabond wouldnt be at risk from a wrong powered light, but the light very much is. The Vagabond will not be switchable voltage, it would be an either/or option.
Sat Sep 11, 2010 10:35 am
Woops! I did realise this. Too much mini Vag on the mind! lol
I corrected the initial post to not confuse anyone else who reads it.
 [ 24 posts ]
Users browsing this forum: No registered users and 81 guests
