| How about a battery powered, 5 stop stepless reducable flash http://paulcbuff-techforum.com/viewtopic.php?f=8&t=856 |
| Author: | kgphoto [ Mon Sep 13, 2010 12:54 pm ] |
| Post subject: | How about a battery powered, 5 stop stepless reducable flash |
How about making a manual exposure, fast recycling, 5 stop step-less, battery powered, 200-400 equivalent watt second on camera bracket mountable (hot shoe) flash? I am thinking of taking a small pack style unit, with the lithium battery, sans modeling light for location and even work. Kinda like the old Norman 200B's or Lumedynes or the current Quantums. I would use this on camera for fill and full flash and probably another unit on a remote stand. I want the pack type system to reduce weight up at the camera level. For the same reason I am willing to forgo the modeling light. Care to discuss the viability and options for this typed of light? |
| Author: | Liquid Rhino [ Mon Sep 13, 2010 2:24 pm ] |
| Post subject: | Re: How about a battery powered, 5 stop stepless reducable flash |
This was topic addressed here: http://www.paulcbuff-techforum.com/viewtopic.php?f=8&t=826&start=50#p5489 |
| Author: | kgphoto [ Mon Sep 13, 2010 3:20 pm ] |
Actually, no. That wasn't the question I asked. I didn't inquire about efficiency of operation. I asked about a light weight head that can be mounted on camera or on a stand with full controls, but no modeling light. No way can I run around with a AB800 mounted over my camera all night at a wedding. A low profile, low weight head ala the lumedyne, norman and Quantums. |
| Author: | BigIronCruiser [ Mon Sep 13, 2010 4:44 pm ] |
When you say "running around all night" at a wedding, you're apparently looking for a more powerful light source in conditions where you're not trying to overpower the sun. One issue against such a product is that pro camera's do a good job at higher ISO's, which means you can get by (in most cases) with high-end speedlights. Another issue is that the R&D cost to bring a new product to market is considerable, and the potential market size for the product you're looking for probably isn't large enough to justify the expense. When ultra-portability is a concern, some photog's use something like the "Perfection Bracket" with two speedlights. Studio strobes, of course, will also be more portable when the mini-Vagabond comes to market.....as long as you're okay with not having the strobe mounted in the hotshoe. My $0.02. YMMV. |
| Author: | kgphoto [ Mon Sep 13, 2010 5:47 pm ] |
Today I can use my existing Norman 200B which is a 200 watt second manual strobe with full, 1/2 and 1/4 power settings and that is it. Or I can buy a $1500 Quantum Flash. I would like to buy a $500-$800, 200-400 Watt second flash with 5 stops of flash output reduction that I can mount to my camera or light stand. Some times I will use it as fill flash on very low power, other times I will use it to overpower or match the sunlight with direct flash or in a small soft box or umbrella. There are many manual power flash users that would love a more controllable flash at a reasonable price and light weight. |
| Author: | kenyee [ Tue Sep 14, 2010 1:03 pm ] |
kgphoto wrote: Some times I will use it as fill flash on very low power, other times I will use it to overpower or match the sunlight with direct flash or in a small soft box or umbrella At typical distances (i.e., not inches from their face), you'd need more than 200WS....more like 600-1000WS if you have any modifiers... |
| Author: | kilonad [ Tue Sep 14, 2010 1:39 pm ] |
B&H Used Department to the rescue: Quantum QFX2 (400w/s, 9 stop range) - $284 http://www.bhphotovideo.com/c/product/8 ... el_X2.html Lumedyne 400w/s battery pack - $349 http://www.bhphotovideo.com/c/product/8 ... y_for.html You might need to buy a cable too, but that's 400w/s for $633. |
| Author: | kgphoto [ Tue Sep 14, 2010 2:15 pm ] |
kenyee wrote: kgphoto wrote: Some times I will use it as fill flash on very low power, other times I will use it to overpower or match the sunlight with direct flash or in a small soft box or umbrella At typical distances (i.e., not inches from their face), you'd need more than 200WS....more like 600-1000WS if you have any modifiers... Unless you are using it in open shade, which is typically what I do or sunset images. My 200 w/s Norman gives me f:8 at about 8 feet from the subject with an umbrella @ ISO 100 settings. |
| Author: | kgphoto [ Tue Sep 14, 2010 2:38 pm ] |
kilonad wrote: B&H Used Department to the rescue: Quantum QFX2 (400w/s, 9 stop range) - $284 http://www.bhphotovideo.com/c/product/8 ... el_X2.html Lumedyne 400w/s battery pack - $349 http://www.bhphotovideo.com/c/product/8 ... y_for.html You might need to buy a cable too, but that's 400w/s for $633. Thank you. That is helpful. Of course that would be adding yet another manufacturer into the mix. My Norman is also available in a 400W/s style. One of the reasons I want Paul to do it, is so there maybe some compatibility between the products. Like maybe the wired controller for when I put this in a location light or use it on a boom, etc. Just keep those RJ-11 connectors happening! |
