| HOBD - White Question http://paulcbuff-techforum.com/viewtopic.php?f=8&t=859 |
| Author: | paultklein [ Mon Sep 13, 2010 10:38 pm ] |
| Post subject: | HOBD - White Question |
Newbie of course - any situation where you use the diffusion sock and the direct-light blocker at the same time? Thanks, Paul |
| Author: | mtheadphoto [ Mon Sep 13, 2010 11:30 pm ] |
| Post subject: | Re: HOBD - White Question |
I thought using it without the blocker might give a bit of a hot spot but really don't know if that's the case. Generally I leave the blocker off if using the sock... |
| Author: | Technical Support [ Tue Sep 14, 2010 10:22 am ] |
Even with a diffuser, some light will travel straight, causing a hotspot. By using the light blocker, all light will be bounced light, then diffused. |
| Author: | paultklein [ Tue Sep 14, 2010 12:29 pm ] |
So, the blocker is also a bouncer! I'll give it a try. Thanks, Paul |
