Tue Dec 29, 2009 2:13 pm
Hi guys,
I bought a Vagabond II used. Now the problem is when I plug in the
charging cable - all it does it shows a red light and the fan turns on for a few seconds then
the light and fan goes off and turns on a second after.
When I detach the charging cable and turn the Vagabond II in either fast or slow mode - it's
beginning to beep constantly, the green led (near the fast,off,slow button) is lit all the time and the red charging led is blinking constantly.
any solution/suggestion for this problem?
please help a wannabe Vagabond user
thanks in advance
Schatti
p.s.: all cables are seated properly and the fuses are not blown
Tue Dec 29, 2009 5:24 pm
that sounds like a sulfated battery, which is quite possible, especially if used (you dont know the care proceedures of the previous owner). Please contact Customer Service to arrange replacing the battery.
TS
