| Vagabond II not charging, beeping sound when turned on http://paulcbuff-techforum.com/viewtopic.php?f=8&t=86 |
| Author: | schatti [ Tue Dec 29, 2009 2:13 pm ] |
| Post subject: | Vagabond II not charging, beeping sound when turned on |
Hi guys, I bought a Vagabond II used. Now the problem is when I plug in the charging cable - all it does it shows a red light and the fan turns on for a few seconds then the light and fan goes off and turns on a second after. When I detach the charging cable and turn the Vagabond II in either fast or slow mode - it's beginning to beep constantly, the green led (near the fast,off,slow button) is lit all the time and the red charging led is blinking constantly. any solution/suggestion for this problem? please help a wannabe Vagabond user thanks in advance Schatti p.s.: all cables are seated properly and the fuses are not blown |
| Author: | Technical Support [ Tue Dec 29, 2009 5:24 pm ] |
| Post subject: | Re: Vagabond II not charging, beeping sound when turned on |
that sounds like a sulfated battery, which is quite possible, especially if used (you dont know the care proceedures of the previous owner). Please contact Customer Service to arrange replacing the battery. TS |
