Fri Sep 17, 2010 8:46 pm
Can someone tell me if and how I can attach a (classic) Lumedyne flash head to an Allien Bees PLM? Of course, I would want it to be in the central axis. Can I use the Lumedyne Adapter for Elinchrom, or the one for White Lightning?
Thanks,
Jan
Mon Sep 20, 2010 1:31 pm
I googled the adapter, but could not find anything that showed it in use. Therefore, I can only assume it outfits a Lumidyne head with an accessory mount that takes the indicated modifiers. Taken at face value, this adapter should be all you need. It appears both Elinchrom and Buff/Balcar models are available, and either should work with the PLM. As to which version you should get, that would depend of if you have other modifiers as well that would take the same style modifier. Unless there is a design issue in the adapter that makes this statement false, there is no inherent benefit of one over the other.
Users browsing this forum: No registered users and 3 guests
