synch on rc helicopter for dual cams
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=875
Author:  PEco [ Sun Sep 19, 2010 4:54 pm ]
Post subject:  synch on rc helicopter for dual cams
Control dual Sony Nex 5 onboard an RC helicopter... I need to synchronize from as far as I can get... 1 mile?
Is this possible... What's the unit I need?
G.
Author:  Technical Support [ Sun Sep 19, 2010 5:19 pm ]
Post subject:  Re: synch on rc helicopter for dual cams
Firstly, our remotes reach 300-400 feet. Even with repeater mode, you would not be able to reach one mile. Pocket Wizard, currently the farthest reaching remote, will only reach a maximum of 1600 feet. Secondly, I do not believe the NEX series has a remote input port. Therefore, I do not know of a solution to work for you, however, I do know we do not have a solution to meet your needs as described.
Author:  PowerEngineer [ Sun Sep 19, 2010 6:52 pm ]
Not sure about the NEX input compatibility but here is one photog's solution for extremely long-range triggering.
http://robertbenson.com/blog/2008/10/20 ... a-trigger/
Author:  reeveswron [ Tue May 01, 2012 10:12 am ]
This link is not working anymore. You know something that's similar to this?
cheers!
RC Helicopter Simulator
Author:  PowerEngineer [ Tue May 01, 2012 2:03 pm ]
DIY long range triggers are usually based on inexpensive walkie talkies. If you Google, camera trigger long range, you will get several of different resources - some DIY and some you just buy. Here is a pretty good description with pictures on Flickr: http://www.flickr.com/photos/majet/sets ... 1167555072. Google should turn up some video too.
