| AB Honeycomb 7' grids real exact diameter http://paulcbuff-techforum.com/viewtopic.php?f=8&t=884 |
| Author: | romanocy [ Sun Sep 26, 2010 1:34 pm ] |
| Post subject: | AB Honeycomb 7' grids real exact diameter |
Greetings, I wonder if somebody will be kind enough to tell me the exact diameter of the AB 7' honeycomb grids. The reason I ask is because I want to know if I can use the AB grids with a strobe reflector that measure 6.8 inches (17.5 cm) on the inside top lip diameter. Thanks in advance. Sorin |
| Author: | Technical Support [ Mon Sep 27, 2010 11:34 am ] |
| Post subject: | Re: AB Honeycomb 7' grids real exact diameter |
they are about 16.5cm, with a spring loaded tab. They would probably hold somewhat in a 17.5cm reflector, but not very well, and there would be too much leakage around the perimeter. |
| Author: | romanocy [ Mon Sep 27, 2010 4:19 pm ] |
Thanks a lot for your reply. As about the grids size, I'm afraid that you are right, the light spill will be, most probably, too much. |
