| Vagabond 2 + Low Wattage Lamp as Recycle Indicator http://paulcbuff-techforum.com/viewtopic.php?f=8&t=895 |
| Author: | ericski [ Wed Sep 29, 2010 2:23 pm ] |
| Post subject: | Vagabond 2 + Low Wattage Lamp as Recycle Indicator |
I was wondering what kind of impact a really, really low wattage modeling lamp would have on the health/capacity of a Vagabond 2? I want the recycle complete indication from the lamp coming back on. Would a 5W (or ideally less) lamp draw down the battery too much? |
| Author: | Technical Support [ Wed Sep 29, 2010 2:43 pm ] |
| Post subject: | Re: Vagabond 2 + Low Wattage Lamp as Recycle Indicator |
Something that low should be fine. It would not stress the inverter and would not draw a huge amount of power. Be sure you are not using a CFL style bulb, however. |
| Author: | ericski [ Wed Sep 29, 2010 2:57 pm ] |
Thanks for the no-cfl heads up, that probably would've been my first type to try. :shock: |
| Author: | Luap [ Wed Sep 29, 2010 7:05 pm ] |
I just did some shots with Einstein modeling on and set at about 40W. Worked fine. |
