Sat Oct 02, 2010 3:34 pm
My CC stop working , won't come on at all, after doing a small shoot I was changing a little step up and did a light meter check and as soon as I popped the strobe it went dead, any suggestion.. !
Sat Oct 02, 2010 9:38 pm
Check the battery contacts, I've dropped mine and the metal tabs had to be smooshed back into place to hold one of the two batteries tight. That's what i would guess.
If the batteries were simply low, it might go into a reset mode because of the voltage drop. Black screen, White screen, etc.
Sun Oct 03, 2010 8:55 am
try removing the memory card.
Sun Oct 03, 2010 11:15 am
TS, Thanks that worked everything seems to be working , I will have to remember that..
Kgf
Mon Oct 04, 2010 9:00 am
That is indicative of a corrupt memory card, which should be replaced (or if you do not save more than 2 set ups, removed)
Mon Oct 04, 2010 12:58 pm
I do not save any of my setups so I will remove it ,, Thanks for all your help!
KGF
Users browsing this forum: No registered users and 50 guests
