| CC stop working http://paulcbuff-techforum.com/viewtopic.php?f=8&t=904 |
| Author: | KGF [ Sat Oct 02, 2010 3:34 pm ] |
| Post subject: | CC stop working |
My CC stop working , won't come on at all, after doing a small shoot I was changing a little step up and did a light meter check and as soon as I popped the strobe it went dead, any suggestion.. ! |
| Author: | mrscott [ Sat Oct 02, 2010 9:38 pm ] |
| Post subject: | Re: CC stop working |
Check the battery contacts, I've dropped mine and the metal tabs had to be smooshed back into place to hold one of the two batteries tight. That's what i would guess. If the batteries were simply low, it might go into a reset mode because of the voltage drop. Black screen, White screen, etc. |
| Author: | Technical Support [ Sun Oct 03, 2010 8:55 am ] |
try removing the memory card. |
| Author: | KGF [ Sun Oct 03, 2010 11:15 am ] |
TS, Thanks that worked everything seems to be working , I will have to remember that.. Kgf |
| Author: | Technical Support [ Mon Oct 04, 2010 9:00 am ] |
That is indicative of a corrupt memory card, which should be replaced (or if you do not save more than 2 set ups, removed) |
| Author: | KGF [ Mon Oct 04, 2010 12:58 pm ] |
I do not save any of my setups so I will remove it ,, Thanks for all your help! KGF |
