Tue Oct 05, 2010 1:09 pm
i got a CC and 2 b1600 units .. but when i set (in the CC) the power to 30ws the b1600 flashes like 160ws. when i set it to 160 it flashes like 500ws. both units do the same
... and ..when im using cyber commander .. the modeling light flickers .. both units
Tue Oct 05, 2010 2:11 pm
When you say "it flashes like..." what are you basing that on? Meter reading, observation? Also, you say the model light flickers, do you mean when just sitting there it flickers?
Make sure all model lamp buttons are pushed in on the back panel and the power slider is to the far right. It sounds like there could possibly be some line noise on the circuit you are using. Switch to a different cicuit and see if the problem persists.
Tue Oct 05, 2010 2:30 pm
"it flashes like" based on a flash meter and observation .. its very obvious thats why you can notice by bare observation .
all the buttons are pushed in ...
and for the circuit .. i already change the circuit and same ..
any other suggestion ?
Tue Oct 05, 2010 2:49 pm
When not using the CSR+'s and adjusting via the back panel, do the flashes exhibit the same behavior?
Tue Oct 05, 2010 3:32 pm
nope .. when using sync cable everything is ok ..
i will re wire all my studio electricity to see if i got a ground problem .. ..
Users browsing this forum: No registered users and 20 guests
