| lastloite hotshoe ezybox connection to alien bee http://paulcbuff-techforum.com/viewtopic.php?f=8&t=914 |
| Author: | planning [ Wed Oct 06, 2010 7:29 pm ] |
| Post subject: | lastloite hotshoe ezybox connection to alien bee |
Has anyone found a workaround to connect an alien bee to a 28" lastolite hotshoe ezybox? |
| Author: | Technical Support [ Wed Oct 06, 2010 7:45 pm ] |
| Post subject: | Re: lastloite hotshoe ezybox connection to alien bee |
What is the outer diameter of the "speedring"ish thing that it uses? I am thinking a speedring insert would work. |
| Author: | planning [ Wed Oct 06, 2010 8:09 pm ] |
apx 5.75" how do I order the part you referred to? |
| Author: | Technical Support [ Thu Oct 07, 2010 10:18 am ] |
We do not sell these seperately, however, you may contact customer service to see what can be worked out, it would need to be the inner speedring for a foldable softbox. Here is a link to one that is very similar, if not the same as ours:http://www.porters.com/easy-open-soft-box-custom-speed-ring-for-white-lightning-alien-bees-monolights.html Note: these are 5.5" in diameter, so i do not know how effective they will be. I did try with an ebay special softbox that is designed similar to the Easy box, and it worked OK. YMMV. |
