| Einstein CSXCV and remote sync http://paulcbuff-techforum.com/viewtopic.php?f=8&t=925 |
| Author: | beaser [ Sun Oct 10, 2010 9:22 pm ] |
| Post subject: | Einstein CSXCV and remote sync |
Once the CSXCV is installed can the wireless trigger be disabled and remote sync or optical used instead (without removing the module) Is it possible to remotely adjust the Einstein using the cyber commander while utilizing optical or remote sync rather than the CSXCV wireless. I did look for this before i posted. Thanks Bryan |
| Author: | Technical Support [ Mon Oct 11, 2010 10:34 am ] |
| Post subject: | Re: Einstein CSXCV and remote sync |
The CSXCV cannot be "disabled" per se, except to uninstall it, but the optical slave and sync jack are still active (unless you disable the slave eye). The optical slave is switchable remotely, so if it needs to be turned on after a remote installation, it can be. |
