 [ 6 posts ]
Thu Sep 30, 2010 9:11 am
I'm already limited to one outlet in my house that doesn't blow a breaker for two Einteins. How many can I plug into one outlet that has nothing else going on? I have 4 more on backorder. :(
Thu Sep 30, 2010 9:27 am
That depends on the amperage of the breaker. A 15A breaker should be able to support 4 lights. The lights will pull about 16-18A initially after firing. But because it is such a short period of time that is does this, you will not trip the breaker (unless you are firing Disco-fever speeds).
Thu Sep 30, 2010 12:07 pm
It depends on the firing rate and how long you fire them. Three to four is generally OK, put if you use four on a 15A breaker and keep firing them as soon as they recycle you will probably blow the breaker in a few minutes.
Wed Oct 27, 2010 10:15 am
I got my v2's in... had positive results plugging 6 into 2 outlets in the kitchen... supposedly on the same breaker. I fired them off on full power about 10 times just to test... looks good!
On another note... 6 model lamps on full power really lights up a room, lol.
Wed Oct 27, 2010 3:24 pm
That's about right . . . three per standard 15A circuit. But separate outlets in the same area of a house are often on the same 15A breaker so you may have to run an extension cord to another room to run six units.
Tue Nov 02, 2010 9:35 am
Luap wrote:
That's about right . . . three per standard 15A circuit.....
W = A * V
So if a "standard" breaker in a house circuit for you guys is 15A @ 110V, that means your power-points are rated at 15 * 110 = 1,650W.
Ours use a 10A breaker as "standard", 10A * 240V = 2,400W.
So we should be able to run (1 or 2) more lights per power-point (circuit) then you guys up there ??
AB (from Downunder :) )
 [ 6 posts ]
Users browsing this forum: No registered users and 61 guests
