| New Einstein V2 Barely Flashes http://paulcbuff-techforum.com/viewtopic.php?f=8&t=969 |
| Author: | rikkflohr [ Thu Oct 28, 2010 5:40 pm ] |
| Post subject: | New Einstein V2 Barely Flashes |
I just unpacked my Einstein V 2 that arrived while I was traveling. I set it the same as my V1 that I have been using for a month. On Full Power, it barely flashes as much as my V1 at 1/256th power. No model lights at all. The Ready light never makes it to Green. DOA or a setting or connection I should investigate? I can add that it won't communicate with the Cyber Commander either. |
| Author: | gwood [ Thu Oct 28, 2010 6:22 pm ] |
| Post subject: | Re: New Einstein V2 Barely Flashes |
I'm having the same problem with one of the two Einsteins I just received last Wednesday. Version 22 firmware. At first I thought it was a seating problem with the power cord into the unit, but now it seems to be failing to fire at power constantly, and the ready icon never turns green. |
| Author: | gwood [ Thu Oct 28, 2010 7:24 pm ] |
As a follow-on, I'm beginning to think it might be a firmware issue -- I can get the 250W halogen to turn on, but only once; when the flash "fires" (more like "barely flickers"), the lamp goes out and stays out, no matter what I do. Selecting "Bootload" from the diagnostics menu doesn't help. As another data point, my diagnostics screen on the Einstein that's acting up has the following values displayed: Cap PWM: 96.8% 496V Model PWM: 0.0% Gate Time: 2280uS In contrast, the Einstein that's still working has these values: Cap PWM: 35.5% 182V Model PWM: 0.0% Gate Time: 200uS No idea if any of these mean anything. Garth |
| Author: | Technical Support [ Fri Oct 29, 2010 9:12 am ] |
Rikkflohr, remove the CSXCV entirely and see if the unit will function normally without it. If that doesn't work, we will likely need to swap the unit. Gwood, It is not a firmware issue, it sounds ardware related. Yours will certainly need to be swapped. BTW, bootload wont do anything unless a micro SD card was installed with firmware. |
| Author: | rikkflohr [ Fri Oct 29, 2010 9:40 am ] |
Technical Support wrote: Rikkflohr, remove the CSXCV entirely and see if the unit will function normally without it. If that doesn't work, we will likely need to swap the unit. . No change, I will call it in. |
| Author: | rikkflohr [ Mon Nov 01, 2010 11:00 am ] |
New unit on the way. Call tag for the other. Great customer service response! |
