Dummy Plugs
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=97
Author:  geogecko [ Thu Dec 31, 2009 11:53 pm ]
Post subject:  Dummy Plugs
Do they came with Strobe unit orders? Or do you have to buy one to go with it?
Author:  Technical Support [ Fri Jan 01, 2010 10:32 am ]
Post subject:  Re: Dummy Plugs
Dummy plugs are separate, but the included sync cord can perform the same function
Author:  geogecko [ Fri Jan 01, 2010 9:54 pm ]
Question.
Will the Einstein need a dummy plug (or sync cable plugged into nothing) to disable the slave tripping when the transceiver module is plugged in, or will the transceiver module automatically disable the slave tripping?
Author:  Technical Support [ Mon Jan 04, 2010 9:56 am ]
The slave eye can be turned off via menu function.
TS
