D90 and CST not communicating
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=970
Author:  mrkvavle [ Sat Oct 30, 2010 10:40 am ]
Post subject:  D90 and CST not communicating
I just received my CST and CSRB and the CST doesn't seem to be receiving any signal from the D90. It's attached to a B1600. The D90 has the flash set to manual and full.
Here is the trouble shooting I've done to figure out whats wrong:
The test button on the CST fires the B1600. Which means that It's likely not an issue with the batteries or any setting on the cst and csrb.
I attached an sb600 to the hotshoe of my D90 and it fires(So I'm confident it's not the hotshoe on the D90).
The only problem I can think of is that the hotshoe connection on the CST is bad. I've looked at the pin on the bottom and it doesn't seem to protrude very much. However I don't know if it's supposed to.
Any ideas?
Author:  mrkvavle [ Sat Oct 30, 2010 1:08 pm ]
Post subject:  Re: D90 and CST not communicating
I just tried it on my D70 and it's firing. The contact point on the d70 is flush with the hotshoe but the d90's contact point is a little bit recessed. Is the pin on the bottom of the cst supposed to be springy or stationary?
Author:  Luap [ Sat Oct 30, 2010 3:13 pm ]
The CST camera contact is spring loaded.
Author:  Technical Support [ Sat Oct 30, 2010 6:47 pm ]
Try pushing down on the CST when attepting to take a photo. Also, are you in live view mode by chance?
Author:  mrkvavle [ Sun Oct 31, 2010 12:14 am ]
The camera contact on my CST is stationary. I tried pushing down and I'm not in live view. I successfully fired it from my D70s. The D70s' contact is flush with the bottom of the shoe. The D90 contact is slightly recessed. I think if the CST contact protruded a tiny bit more and had spring in it that I'd be able to fire it from the D90.
Author:  Technical Support [ Mon Nov 01, 2010 9:13 am ]
If the contact is not springy, then we will need to swap that out for you. Call or email custoemr service, and they will be able to arrange for that.
