Sat Jan 02, 2010 6:42 pm
I am the owner of the original Vagabond portable Power System. Due to a physical move and other factors, I was not able to charge my unit in over a year. What do I do to get it back into operational condition? Thanks
Mon Jan 04, 2010 10:20 am
You can first try to charge teh unit, and see what will happen (i.e. see if it will hold a charge). Likely it will not. At this point a simple battery replacement ($39.95) will get you going, assuming all other components are performing properly, and there should not be any reason they don't.
TS
Users browsing this forum: No registered users and 40 guests
