Order 230v version question?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=992
Author:  yan [ Tue Nov 09, 2010 4:01 am ]
Post subject:  Order 230v version question?
Hi,
I'm not sure if i can post the question here or not. If i'm posted in wrong section pls forgive me.
I'm going to order AB1600 and Vagabond II and i'm going to give it to my brother as b-day present who live in oversea country. Since his country electric Voltage is 230v, can i change my B1600 unit into 230v version?
If i change it to B1600 into 230v version, can i still power with Vagabond II?
Thanks and Regards
Yan
Author:  Technical Support [ Tue Nov 09, 2010 10:04 am ]
Post subject:  Re: Order 230v version question?
no, 240V bees cannot be run from the VII. However, we are coming out with a 240V Vagbond mini in the near future.
Author:  yan [ Tue Nov 09, 2010 10:37 am ]
Hi,
First of all thanks for the answer.
Correct me if i'm wrong here.
1. I can order the AB1600 230v version with 10$ extra and can plug in to any electrical outlet in oversea country which use 230v for power source.
2. Only Vagabond mini 230v can use with AB1600 230v version.
- And last when Vagabond mini 230v will be available? In this year or next year? Because if question 1 and 2 is right i want to place the order all together in one time.
Thanks in advance
Yan
Author:  Technical Support [ Tue Nov 09, 2010 11:23 am ]
1&2 are correct. We are expecting to have the Vagabond mini within the next few weeks.
Author:  glenburnett [ Tue Nov 09, 2010 12:09 pm ]
You can't order from the US store if you're from Europe etc.. so you should use the EU store here:
http://paulcbuff.eu.com/cms/
Author:  Technical Support [ Tue Nov 09, 2010 12:13 pm ]
Right, we must bill and ship to a U.S. or Canadian address. If one or both do not apply, you should contact the EU distributor (linked above) or the Australian distributor https://paulcbuff.com.au/cms/
Author:  yan [ Tue Nov 09, 2010 8:15 pm ]
Thanks for the reply and info guys.
I'm in US and i going to bring down when i visit to my brother.
Thanks again ...
Yan
