c2thew wrote:
Tried the metal paper clip and could not get the cybercommander to complete the circuit so it does appear that there is a connection error. I did try connecting the CC via the PC port using a 2.5mm male cord to a female end sync cable in which the cybercommander triggered the strobes however for how i plan to use the einsteins, i will need that sync port to be operational to manually trigger other strobes.
Certainly understandable, and it does point to the hotshoe
c2thew wrote:
and I was not using live view with my 5d2 which would still send a trigger to the hot shoe regardless if live view was or was not on.
With the correct settings, some Canons, like the 5DmkII can shoot non dedicated lights in live view. Other Canons, like Rebels, cannot as they do not have the same options (silent mode 1 and 2, or something like that)
c2thew wrote:
thanks for the feedback. time to make a call
No problem, and yes, it will need to come in, though it should get turned around quickly.
