 [ 11 posts ]
Mon Aug 29, 2011 4:36 pm
claudio1612 wrote:
Technical Support wrote:
As well as the open studio routine, be sure the slider is to the far right on the light, and specified on the CC.
When on the main screen, do you have a white dash at the bottom for that channel? Or is it gray? Do you have a vertical blue bar for that channel?
The slider was on the 1/1 position (far right).
I will check the screen on the CyberCommander and come back tomorrow to post this.
Regards
Claudio
I checked today and the result at first was the same as the first day (not working).
However, and out of nothing at all, the device started working. I was able to control the light output of the ABR800/CSRB+ combo with the cyber commander.
I had to wait for about 30-45 seconds for it to work.
I repeated the test with the same result. I believe this issue is solved for me.
Thanks for your help.
Claudio
 [ 11 posts ]
Users browsing this forum: Google [Bot] and 63 guests
