Fri Oct 14, 2011 9:22 am
I have 2 early 1990's vintage Ultra 600 units. I just picked up the Mini Lithium and I love it.
Just one question-I'm not getting nearly the number of pops at full power (about 250ws I think) that is stated in the specs. Might this be due to older circuitry; maybe analog components vs. newer digital?
Would an Alien Bee 800 help in this regard? Thanks.
p.s.-any idea why the VML won't charge an iphone?
Fri Oct 14, 2011 10:31 am
Assuming the VML is fully charged, which is to say the LED on the charger did turn red while charging, then turned green when complete, you should get 800-1000 shots with one light at full power (300Ws). A big drain of power would be the model lamp, so be sure it is off. A 150W bulb would drain the unit in less than an hour without any shots from the light.
Your iPhone will not charge via the USB probably because it requires a 5VDC 1A power supply. The VML USB provides a 5VDC .5A supply. However, a wall charger plugged into the AC outlet will easily charge the phone.
Users browsing this forum: No registered users and 107 guests
