 [ 6 posts ]
Sun Nov 20, 2011 12:27 am
Hey folks, I wonder if anyone can comment on the difference between the pre 2009 11R and the newer 11LTR. From what I can see the newer version is deeper/longer and has a polished interior.
I own 12 Ultra 1200s with the original 11" sports reflector and I am considering upgrading to the x1600s (the Ultras are beginning to fail) and I am wondering if it's worth upgrading the reflector too. Several of my arenas have upgraded lights and we are now struggling to overcome ambient, so if there is an improvement I will likely try the new ones out.
Thanks,
Shane
Mon Nov 21, 2011 11:00 am
There will be a higher output, but a smaller beam spread. Don't forget you will also be upping the output by the light upgrade as well.
Mon Nov 21, 2011 2:16 pm
Any idea what the spread on my reflectors (the old ones) are? I know that the new ones are 28 degrees. It's a college arena, but the catwalks are low and far back from the court. I probably have a bit more spill than I would like, but not by much.
There is only a 60ws difference between the 1200 and 1600 correct? That's assuming my 1200s actually hit full output, which is unlikely.
Shane
Mon Nov 21, 2011 2:35 pm
The old 11R was about 45 degree spread. And yes, there is only a 60Ws difference.
Mon Nov 21, 2011 4:17 pm
Thanks guys, so hopefully between the 10% power increase and the new reflectors I should be able to gain maybe a full stop?
Thanks,
Shane
Mon Nov 21, 2011 4:54 pm
I would say 1/2 to 3/4 of a stop, assuming the Ultras were performing properly.
 [ 6 posts ]
Users browsing this forum: No registered users and 81 guests
