Sat Dec 17, 2011 11:10 am
I'm getting periodic extra flashes from one of my 1600's. I'm using PW Flex/AC9 to trigger it and every so often I'll get a extra "glitchy" mis-flash. Sometimes the first flash is at the proper power, and sometimes it isn't.
I typically have two plugged into the same outlet and it is only the one that is having the problem so I don't think it is a line noise issue. I do need to try switching the which Pocket Wizard I'm using on it but for the first few shoots where I saw it (I thought it was overheating,) I wasn't being meticulous about keeping the same trigger/strobe combo so I don't think it's a trigger issue.
Could it be a flaky flash tube? It does happen after I've been shooting for a bit so could it be overheating? Is there a way to check?
Sat Dec 17, 2011 7:37 pm
I would try a different circuit. Also, if you are using an extension cord or power strip, remove or replace those and see if the condition improves. Swap components one at a time to see if you can isolate the problematic component. You will also want to contact LPA to see if there is any known issue on the PW side.
Users browsing this forum: No registered users and 96 guests
