kenyee wrote:
MattMoore wrote:
AB will fire fine (full) on first attempt (essentially a dump), but will not fire proper power (faint "spark" in flashtube) after each subsequent firing attempt regardless of power setting shown on CC.
On the back of the AB, does the dump light keep flickering red?
If so, I think you'll need to switch to CSRB+ instead.  I had a similar problem w/ Radiopopper JrX's a while back, but it only happened to one B1600...
No, it is only red momentarily while the power cycles on the AB on the initial full power pop, then it goes green (when on Vagabond Minis).  As mentioned before, everything works fine when on AC/outlet power.
So far the only variable I can see is the use of the Vagabond Minis (where problem exists) and AC/outlet power (no problems at all).
After the initial full power pop, it goes straight to green, as it does the low power "spark" in the flash tube deal.
I hope I don't have to use the CSRB+, as I went with the CSR+ to avoid having to use batteries.
