Sun Feb 05, 2012 3:05 pm
I've had 2 occasions now where the Cyber commander stopped controlling some functions on my Einstein mid shoot. The best I can tell is that the preset memory might have changed. Is there a way to find out quickly what preset the CC is on, without scrolling to the Open Memory Screen? And does the CC "Light Setting" window override the memorized setting being used? And when everything is powered down, and then powered up again, which setting will start up? The last memory preset used, or the "Light Setting" last used?
After each memory preset is made, is there a way to read out what they were set to on the CC? Or do you have to write down each parameter for each memory setting and carry that list around with you?
Stan
Mon Feb 06, 2012 11:41 am
I carry around a written list of setups that I saved on my 2G microSD card because I have a mix of Einsteins and legacy lights. All lights set to FULL. But let me clarify, the setups are only a starting point because each and every place I travel to is different and I always adjust as needed(new adjustments I rarely save). Sometimes I just power it all up and adjust on the fly from the last preset I used.
RMS
Mon Feb 06, 2012 6:06 pm
Cyber Commander does not display what memory setting it is on, as with any change will then not technicallly be that setting. There is no listing of what settings are made to a particular saved location; however, when opened, the displayed graphics will give you a pretty good idea of what those settings are.
When everything is shut down, if the CC is left to shut down, it will wake up to the last configuration used, saved set up or not.
Users browsing this forum: No registered users and 162 guests
