Thu Feb 23, 2012 6:39 pm
Greetings, I connect my Cyber Sync plus to the light AB800 with the Cyber Command but it does not extinguish the modeling light.
Fri Feb 24, 2012 10:02 am
Simply attaching the CSR+ to the light will not extinguish the model lamp. You must have the light properly programmed and have the MODEL MODE = OFF set in the set up menu. If everything is correct, you should have a vertical blue bar on the main CC screen. Within the travel limits of this blue bar, you should have a gray dash. This is the indicator the model lamp is set to off. If this dash is red, then the setting is incorrect in the Cyber Commander.
Users browsing this forum: Google [Bot] and 67 guests
