 [ 11 posts ]
Wed Mar 14, 2012 2:32 pm
The steps to turning off the Einstein via the Cyber Commander and saving as a set up are as follows:
SAVING YOUR CURRENT SET UP
-Use the right joystick left or right to return to the SETUP SCREEN
-Use the right joystick up or down to select SAVE AS, then press in with the right joystick
-Use the left joystick to select an internal or SD card save location (Internal1, SD50, etc). Used SD locations will appear in blue, open/unused SD locations will be in white. All Internal save locations will be white, so be careful to not overwrite a set up accidentally.
-Rather than starting with SD1, I recommend saving locations with SD50, and working "backwards". This will be quicker to access when recalling a saved set up than SD1, due to the individual channel settings in the OPEN MEMORY screen.
TURNING THE LIGHTS OFF
-Press any joystick in any direction on the Cyber Commander to wake it up.
-Once awake, use the left joystick left and right to select the ALL channel setting.
-Use the right joystick left or right to scroll to the SETUP screen
-Use the right joystick up or down to highlight LIGHT SETTINGS, then press in with the right joystick
-Use the right joystick to highlight POWER
-Use the left hand joystick UP or DOWN to highlight STANDBY.
(be careful to not use the left joystick left or right, or you will change channels)
-The lights should now be in STANDBY
-Repeat the above save proceedures to save this new configuration. Be sure to select a new (white) SD location when saving.
RECALLING A SAVED LOCATION
-Use the right joystick to the left or right to enter the SETUP screen.
-Use the right joystick up or down to select OPEN MEMORY, then press in on the right joystick
-Use the left joystick left or right to select the saved memory location you wish to recall
-Press in on the right joystick, the display on the Cyber Commander, as well as the lights, should reflect the changes between set ups.
NOTE:
-Only one STANDBY save location is needed, regardless of the number of saved location with various lights that are "on".
 [ 11 posts ]
Users browsing this forum: Bing [Bot] and 71 guests
