Thu May 10, 2012 5:16 am
HI there !
no matter what i try, with TT5 and PMC2 if i go on TLmode the modeling light keeps going on no matter what i do. this is very annoying..... in classic channel no problem. I have tried just about every setting and i finally removed the bulb.
but i can ear that the powering of modeling light is still active and drawing power from the VLM.
even if i manually turn the model light to "OFF", next time i press the trigger it will just turn back on.
i have tried ALL the settings on the TT5 regarding modeling light and so...
What do I have to do to have the model light remain on "OFF" position ?????
Thu May 10, 2012 9:32 am
There is a setting in your transmitter that allows control of the model lamp from the flash head. You will need to contact PocketWizard for specifics.
Users browsing this forum: Majestic-12 [Bot] and 103 guests
