Tue May 15, 2012 3:42 pm
Hello, i just bought the ones in the title, and I am very dissapointed. Tthe battery dies out after a few shots, even it is just unplugged from charging. I restart the Vagabond Mini, then it fires a few more. What is the problem? I have even charged the battery out of it's casing. No difference.
Cosmin
www.cosminmarin.ro
Tue May 15, 2012 4:11 pm
If you are using the model lamp, be sure to turn it off. If it still does this, and either the LED next to the USB port goes out or turns orange, or the three "fuel gauge" LED's go out, then there is an issue with the inverter or battery. This will need to be corrected under warranty. You will need to contact the distributor from whom it was purchased to make arrangements.
Users browsing this forum: No registered users and 266 guests
