Sat Jun 02, 2012 5:23 pm
I'm buying and Einstein system with 3 lights and commander and receivers. Other than having to replace batteries, any reason not to buy the receiver with the batteries?
Sat Jun 02, 2012 8:59 pm
For the Einsteins you do not want the CSR+ or CSRB+, as they will not communicate the power control (as well as some other functions). You will want to go with the CSXCV http://www.paulcbuff.com/csxcv.php it is designed specifically for Einstein, and costs considerably less.
For use with other lights, battery versions can work with a wider variety of lights (including speedlites and other brands, albeit without power control), but will shut off after an hour of non-use.
AC powered recievers will work with most mono lights (though not all), and will maintain power as long ac they are plugged in. This is good for permanent/semi permenant installs or hard to reach apllications where a breaker may be used to apply or shut off power.
Users browsing this forum: No registered users and 80 guests
