I believe the reason is E-TTL controls not only metered output (where "TTL" originated), but it also controls the wireless communications between two flash units. Since the CyberSync system breaks the TTL communications path, the 580 is not able to give a command the 430 can understand, as the 430 does not have a "dumb" slave eye like studio flashes or Nikon's SU4 mode.
I have never heard of anyone getting this set up to works on a Canon system.
The solutions would be to either use an additional CyberSync reciever (and and adapter like our SLFA
http://www.paulcbuff.com/slfa.php) for the 430, or get a dumb slave eye that will fit to the foot of the 430.
