Mon Jul 09, 2012 11:52 am
My wl3200 doesn't seem to be giving me a full power burst. This is not a recycle timing question as I am waiting a good deal of time between testing it. It's very sporadic, at times a token small flash no where near the output of the levels it's set at and then other times the full flash power. Again this is not a timing question as I've had real trouble with it and patiently tested it out.
Any ideas is this strobe dying?
thanks, jeff
Mon Jul 09, 2012 1:19 pm
Are you using the telephone connection? If so, have you tested with out the telephone connection in use? Do you see any difference when you switch between the two?
If you are using the telephone connection, it is likely an external issue (how its used, what its used on, etc)
If this occurs without the telephone connection, then there may be something more at play.
Mon Jul 09, 2012 1:36 pm
at first i was using the CyberSync Receiver with the telephone connection, but as the problem persisted I tested a variety of ideas and even without anything connected just pushing the test button on the back (nothing connected) I wasn't getting the full output consistently.
do I need the sad emoticon?
Mon Jul 09, 2012 4:34 pm
It should probably come in. However, before you trigger the light, is the green light coming on to indicate a full recycle, or are you timing it?
Users browsing this forum: No registered users and 75 guests
