Thu Sep 27, 2012 3:12 pm
The green led want no go green it is only a bit green but not right bright.
Vagabond 2 is in on the walloutlet always
Shal I change the accu ? Vagabond is about 2-3 yars old
Thu Sep 27, 2012 3:54 pm
By "accu", I presume you mean accumulator or battery? It is possible the battery is getting old and reaching the end of its service life. In the US, one can take the battery to an auto parts store to have the battery tested under load. I am sure the same can be done in Europe, if not at an auto parts store, then at a battery specialty store. A visual inspection could show swelling, cracks, leakage or corrosion, as well a sulfur or rotten egg smell could be present. Any of these observational problems would indicate a bad battery.
You may wish to test the charge voltage of the charging system as well. Disconnect the battery from the inverter, making sure the leads do not touch if left on the battery or on the inverter. In either case, this can cause damage, and potentially a fire (just like any battery). Plug the inverter into the wall outlet and leave it switched off. Meter the voltage coming from the red and black wires or connections on the inverter. This should 13.6 to 14.2VDC (optimum being 13.8VDC).
Also, it could be an increase in ambient lighting that would cause the LED to appear dimmer.
Thu Sep 27, 2012 4:37 pm
May a use another batterie with vagabond
It shall have 12 volt and minimum power of 20 ah right ? May i use 12 volt an 48 ah or will ot cause demage ?
Fri Sep 28, 2012 8:52 am
The minimum capacity battery for a VII inverter would be about 11Ah. Otherwise, as long as it is a 12VDC battery, it can be used.
Users browsing this forum: No registered users and 221 guests
