Fri Jan 04, 2013 12:28 pm
When the left joystick is pressed and held down to 'turn off' the unit, is it actually TURNED OFF? Or is this merely a 'stand-by' mode that is still using power from the cells?
Fri Jan 04, 2013 3:42 pm
It is a standby mode that allows immediate triggering when a signal is given from the hotshoe or sync jack. When running the current firmware, the power draw while asleep is 4 micro-Amps (or .004 mili-Amp).
Users browsing this forum: No registered users and 66 guests
